Hi Guy's,
Just wondering if VDJ 8 supports the Hybrid Voxoa m70? I am using CDJ 1000's and Virtual timecodes... the mixer itself is able to scroll / Select / FX etc but the timecode is not showing up on the software? Is this an firmware/driver issue with the mixer?
Thank you in advance
geposted Thu 24 Sep 15 @ 4:01 am
M70 is natively supported, meaning that all the MIDI part should work as a plugn play unit.
There should also be a "special" button in the AUDIO tab in VirtualDJ Settings offering the pre-defined audio configuration.
Timecodes are not pre-set, but i suppose that if you press on the TIMECODE button to the right side of the AUDIO settings tab, VirtualDJ will auto-create the necessary audio configuration, since the unit offers 2 Inputs as far as i can recall.
If that is not the case for you, i cant think of anh other reason, since the unit doesnt offer any driver tobe installed.
So please provide us more info on how you have connected all you units and a screenshot of your Audio configuration
geposted Fri 25 Sep 15 @ 4:22 pm
