Posted a long time ago about using this controller with V8. I have tried DLing the mapper for V7 as told, but no luck.
Am I missing something?
geposted Mon 28 Sep 15 @ 7:25 am
well, the author bases detection on a Sysex that may change from unit to unit, and a Drivername which is not "secure" at all, so do this...
- Open VirtualDJ 8, goto Settings-->OPTIONs tab
- Enable the "Show Advanced Options" from top
- search for the setting "CreateMidiLog" and set it to Yes
- Close VirtualDJ 8
- Make sure the unit is connected to USB
- Open VirtualDJ 8 and close it again (dont have to use the unit or anything else)
- Post here the content of the Log Report.txt file you will find in /documents/VirtualDJ folder.
Will provide you some test mapping files after i get the above.
- Close VirtualDJ 8
geposted Wed 30 Sep 15 @ 12:40 pm
Will do tonight.
geposted Fri 02 Oct 15 @ 5:05 am
Got it working. Thanks so much! Love the support here!!!
Now time to get mapping!
geposted Sat 03 Oct 15 @ 8:06 pm
