Forum: Old versions
Topic: Multiplex support
Hi
I am a new KJ and wondered if VDJ has multiplex capability? many of the discs we purchased have a main vocal on one side, which is not required. Any advice gratefully received.
geposted Thu 01 Oct 15 @ 7:48 pm
VDJ doesn't play discs directly, you would need to convert them to CDG or a video format like MP4 first.
"SBDJ StereoChannel" worked for me, is an add-on effect that you can use to eliminate the voice and select left channel to be hear in both sides.
This effect works just as Multiplex in Karaoke machine does, specially for those karaoke files that have voice on it.
Hope that all of you that find this advice helpful reply if it works for you so it would help others.
