Does anybody know to where the History files get sent to?
It says to your VDJ account. I just had a look but can't find any files.
In Documents/VirtualDj there is a file waiting to be send. It has a filedate of this morning, which is correct, no internet connection.
There is no file for yesterday evening where I had an internet connection. So I assume this file was sent to ... somewhere.
geposted Fri 02 Oct 15 @ 11:54 am
The website part of this feature is still in development, but it will indeed be possible to see your playlists on your account in the future.
geposted Fri 02 Oct 15 @ 11:58 am
Okay, thanks for the info.
Are the files already sent getting stored already, or does it make sense to disable this feature until release of the website function?
While we are at it.
If you collect all this informations, a nice little DB with some good algorithms could be build.
It could be used like the shazam feature or for the geniusDJ or Livefeedback.... mmhm....
While we are at it.
geposted Fri 02 Oct 15 @ 12:07 pm
Note that it does not send files, only playlists. Traffic should be very low, so not too much reason to turn it off I guess.
geposted Fri 02 Oct 15 @ 12:10 pm
Yes I know. I opened the file with an editor to have a look at the data.
Bad wording, sorry.
Bad wording, sorry.
geposted Fri 02 Oct 15 @ 12:11 pm
