Topic: Automix dual deck bug
Random track playing in deck 1
Start automix
Track finishes in deck 1 but the automix does not start automatically!
geposted Fri 02 Oct 15 @ 2:51 pm
It starts playing the next track on deck 2 for me.
Ah, ok. Is there a setting causing this?
Not sure which setting could cause it not to work.
If you just have one deck playing before you start automix it should detect it.
Do you see the second waveform and mix in/out points appearing on the first deck when you start automix?
