Topic: Bug in column ordering
If you manually order your browser columns, close and reopen VDJ, the ordering is saved and restored, as you would expect it.
But if you disable a column at one time and reenable it at another, it won't be in the order you set it to.
Instead the default ordering is used.
I would expect the column to be at the position I set it to.
geposted Fri 02 Oct 15 @ 3:36 pm
