So I recently build my own music production PC and the problem which I'm experiencing after installing Windows 7 Home Premium and of course Virtual DJ, is that every time I click on the icon an error dialog appears saying...
"The program can't start because freetype.dll is missing from your computer. Try reinstalling the program to fix this problem."
Followed by another dialog saying...
"QuickFontCache.DLL not found!"
I have tried reinstalling Virtual DJ multiple times and still no luck!
Any help?
Any help?
geposted Fri 02 Oct 15 @ 11:19 pm
          OK so it's telling you that freetype.dll is missing. Did you search your computer and confirm that you do actually have that file?
    geposted Sat 03 Oct 15 @ 9:07 am
          Also, VirtualDJ itself is not using this dll, so you should probably have a look in Documents\VirtualDJ\plugins and remove the plugins you don't use.
    geposted Sat 03 Oct 15 @ 9:17 am
          @Adion
I haven't been able to install any plugins since i can't even launch virtual dj! I also had a look in the plugins folder like you said and all subfolders are empty.
@groovindj
I did a search for "freetype.dll on my hardrive where i installed Windows and it did come up with the "freetype_x64.dll" version used by FL Studio (I never use Fl Studio anyway!) so should I uninstall FLS?
@groovindj
geposted Sat 03 Oct 15 @ 3:18 pm
          UPDATE
Its ok gentlemen! I uninstalled FL Studio and Virtual DJ is now is fully up and running! Ableton Live all the way!
geposted Sat 03 Oct 15 @ 3:21 pm
          Well done, and thanks for posting the solution.
    geposted Sat 03 Oct 15 @ 3:35 pm
          And to conclude it was the use of rewire in VirtualDJ.
    geposted Tue 06 Oct 15 @ 11:39 am
