-Reverb and Echo have switch to enable trailing stop when disabling the effect
-Feedback and Highpass parameter added to flanger
-Read Serato track colour from tag when cues are read
-Clone also clones loop
-Fix automix_skip when deck is paused while automix active
-Fix cue_name action problem in some cases
-Fix possible plugin issue when showing effect gui
-Fix possible track cleaner crash
-Fix possible video crash
-Fix detection of ASIO drivers with REG_EXPAND_SZ type (like Rane ASIO driver)
-Fix some problems with bad vga drivers
-Fix cdg using scroll preset
-Fix advanced audio channel selection hidden behind config window on Mac
-Fix renaming playlists and only changing the case
-Fix video flickering in track edit when source length was 0
-Fix possible batch analysis lock up
geposted Sun 04 Oct 15 @ 7:25 pm
after up date this
geposted Sun 04 Oct 15 @ 7:27 pm
"Clone also clones loop"
Thx for this i sent a messag this morning about that (y) you are the Best :-)
geposted Sun 04 Oct 15 @ 8:13 pm
Im not able to write in the previous public version but last night the video panel of the skin by fruit doesnt look like it used to, also vdj doesnt recognize my reloop neon pad controller when the VGA for external projectors its connected first.
geposted Sun 04 Oct 15 @ 8:37 pm
What does this mean?
geposted Sun 04 Oct 15 @ 10:00 pm
Thank you for this but if i move the crossfader to other deck the effect still stops, so just another step and you will be up to the standard. I put echo on my scratches sometimes but still cant do that with virtual dj. The position of the crossfader or the line faders shouldnt effect the echo , the echo sent directly to the master output.
geposted Sun 04 Oct 15 @ 10:16 pm
Thank you for updates. Fruit Skin fine with me.
geposted Sun 04 Oct 15 @ 11:14 pm
Works ok, tail needs to trail longer. The way it is makes an abrupt stop in sound.
Just doesn't sound natural.
geposted Sun 04 Oct 15 @ 11:48 pm
Wow, lots of quick responses to forum queries this beta
more info needed for the cue_name and fx gui fixes if we're to properly test.
geposted Mon 05 Oct 15 @ 1:55 am
I agree with breaker, there's a mis-balance on the tail, "pause & effect off" should be the same output as "pause" with the fx on.
but thumbs, +1 & like for the introduction of this.
geposted Mon 05 Oct 15 @ 2:16 am
Total playing video freeze
the program quits without warning when operating
the program closes the drive effect_dock_gui
geposted Mon 05 Oct 15 @ 3:12 am
I checked again, and that's exactly what it is doing. The trail is simply what you would get if the input is stopped but the effect continues to run.
geposted Mon 05 Oct 15 @ 3:44 am
After reload another song,Mouse no longer displayed as a Scratch Arrow.
geposted Mon 05 Oct 15 @ 4:16 am
asthedj wrote :
after up date this
According to my experience, it should have a relationship with the resolution or video card drivers.
geposted Mon 05 Oct 15 @ 4:20 am
No it's not long enough. It doesn't fade out completely.
It should fade until nothing is left and right now it's only fading 2-3 max and then just stops.
geposted Mon 05 Oct 15 @ 4:24 am
repeat
geposted Mon 05 Oct 15 @ 4:32 am
1、A lot of people feed back to me,When loading APE format file,Appear to load only ten seconds.
2、Video Plugins - Milkdrop8 intermittent flash screen
Opera System:Windows 8 - 10
Turn up the strength knob, i think its like the feedback knob.
geposted Mon 05 Oct 15 @ 5:15 am
asthedj wrote :
after up date this
Same problem on a MBPro 13 inch retina
geposted Mon 05 Oct 15 @ 6:41 am
Could you send me your settings.xml file?
Is it working when you rename it?
Tried different window sizes, but it remembers them all correctly here.
geposted Mon 05 Oct 15 @ 7:56 am
