The newly (yesterday?) released support for the Pioneer DDJ-SB2 seems to have a small bug: The vu-meter leds are not working.
For them to work, please add the following lines into the device file:
<bar cc="0x02" min="0x00" max="0x7F" name="CH_LEVEL_LEFT" channel="0" />
<bar cc="0x02" min="0x00" max="0x7F" name="CH_LEVEL_RIGHT" channel="1" />
and the following two lines into the map file:
<map value="CH_LEVEL_LEFT" action="deck 1 get_level" />
<map value="CH_LEVEL_RIGHT" action="deck 2 get_level" />
Thanks a lot!
Thanks a lot!
geposted Mon 05 Oct 15 @ 7:48 pm
VU Meter Leds are already available in the default definition. Those are named as VU_METER (deck dependent) and you should be available to map those as get_level.
The VU_METER Key was indeed not assigned in the default mapping file .
Fixed in builds ending at xxxx.1071
geposted Mon 05 Oct 15 @ 11:32 pm
Hello,
I was wondering if there was a full mapping to Virtual DJ for the DDJ SB2? Including the FX - TransPad - and everything that it could work as it does for Serato?
geposted Sat 24 Oct 15 @ 12:47 pm
I just returned my DDJ-sb2 as it was too difficult to setup. I also found out that it's not supported by vdj yet.
So much for plug and play.
I'm using version 7.4.6
geposted Thu 12 Nov 15 @ 12:06 am
It is supported by version 8.
geposted Thu 12 Nov 15 @ 7:43 am
