Not sure why, but i no loger get any sound when using track cleaner. Is there a setting i may have activated?
geposted Tue 06 Oct 15 @ 8:00 am
Headphones output in audio incorrectly set up perhaps?
geposted Tue 06 Oct 15 @ 8:18 am
Indeed it was. Thank you
Another question, can i clean track on Home PC then transfer the file created to main DJ pc?
geposted Tue 06 Oct 15 @ 8:19 am
Yes, but you have to make sure that you copy both the .vdjedit and the original file.
geposted Tue 06 Oct 15 @ 8:27 am
OK i see, needs to be in same directory/location as one edited
edit source="C:
Just creates an xml file with edit location/time etc
edit source="C:
geposted Tue 06 Oct 15 @ 8:28 am
If the file is in the vdj database, it should be able to find the correct source file even if it's not in the exact same path.
geposted Tue 06 Oct 15 @ 8:33 am
ok thanks
geposted Tue 06 Oct 15 @ 8:35 am
