Forum: Old versions
Topic: First MIDI Fighter 3D Questions
Is there a way to re-calibrate the gyroscope? Right now, it way off center. I have tried the utility program from DJTT, but maybe I am missing something.
Using the mapper from secretseven. Left Side Button 3 is mapped to action_deck 1 ? deck 1 leftdeck ? deck 3 leftdeck : deck 1 leftdeck : deck 2 rightdeck ? deck 4 rightdeck : deck 2 rightdeck. Right Side 3 is the same.
The ideal action is to toggle between active decks on each side. The right side works perfectly and only changes decks 2 & 4. The left side performs the action correctly once, then switches between the right decks. Any thoughts?
geposted Tue 06 Oct 15 @ 10:31 am
I suppose the gyroscope is some <slider>, right ?
You can determine the .. min="" max="" zero="" inside the <slider>
Left Side button (toggles between deck 1 and deck 3) : deck 1 leftdeck ? deck 3 leftdeck : deck 1 leftdeck
Right Side button (toggles between deck 2 and deck 4) : deck 2 rightdeck ? deck 4 rightdeck : deck 2 rightdeck
Deck action works. Thanks.
Will dig more on the gyro...
Does anyone use the MIDI Fighter 3D in their rig?
