Hi,
I just got a VMS4 from a friend. I downloaded Virtual DJ LE, and it works fine. The problem is that my mixer is not talking to the program, so that pushing the buttons on the mixer has no effect on the program. I read some things about updating firmware but when I go to my Virtual DJ folder through All Programs, there is no option for that. I am very new to this and don't know much about computers either so keeping answers simple and thorough would be great. I really want to start making music with my VMS4 but I can't do that until I can actually use it. I'd appreciate any help you can give me.
Thanks,
Lizz
Thanks,
Lizz
geposted Fri 09 Oct 15 @ 7:01 pm
is the vms recognized by your os ?
did you install the according Asio drivers ?
geposted Fri 09 Oct 15 @ 7:03 pm
I did install the right ASIO drivers, and the VMS is showing up under devices, if that's what you mean.
geposted Sat 10 Oct 15 @ 7:37 pm
please post a screenshot of the windows asio panel when the vms is connected
geposted Sun 11 Oct 15 @ 9:07 pm
Ok, I do not know what an asio panel is or how to bring it up, but I'd be happy to do so once I've been enlightened. : )
geposted Tue 13 Oct 15 @ 6:20 pm
windows start button/ American Audio Asio driver/ Asio Settings
geposted Wed 14 Oct 15 @ 7:42 am
geposted Fri 16 Oct 15 @ 8:06 pm
Try to follow instructions from ... https://virtualdj.com/wiki/midinotdetected.html
geposted Fri 16 Oct 15 @ 8:13 pm
make also sure you switch you unit to 8out ( front panel of the VMS ) and reboot again.
seems you are working in timecode mode (4in - 4out)
geposted Fri 16 Oct 15 @ 8:21 pm
Hey,
I tried following the instructions. I got to #7 on the first list to find that there IS no "LowerFilters" option. Both have an "UpperFilters", though. I didn't delete anything at this time. This problem that the USB port thinks my VMS is a mouse or something seems like a likely answer.
I now have my VMS set to 8-out and the panel looks like this:
Also I lost my headphones so now I definitely can't hear anything regardless. _._ I'll be back when I get some new ones. Thanks for all your help!
geposted Sun 18 Oct 15 @ 4:55 pm
Custom skin on the VMS follows the 3-1-2-4 Deck order.
To assing the decks correctly to your midi logs, please set up your asio settings like shown on the screenshot:
geposted Sun 18 Oct 15 @ 5:48 pm
