Seem to have lost LED functionality along the way. Not sure if it is an issue with this build, as I have not used the controller in quite some time. All other functions still work.
MBP 15'" Retina Build 2483.1072
Anybody have similar issues?
geposted Sat 10 Oct 15 @ 2:05 am
If it's X1 MK1 then perhaps you made some changes on the controller itself via Controller Editor?
You need to load the "default" template from NI controller's editor to make the controller work properly. Also make sure you switch the unit to MIDI mode.
geposted Sun 11 Oct 15 @ 4:01 pm
Seems to be working A-OK now. Some of the LED scripts were replaced by numbers only, so I just re-mapped them. Opening Controller Editor helped as well.
Thanks as always.
Thanks as always.
geposted Tue 13 Oct 15 @ 8:01 pm
