-Localization of default skin (texts and tooltips)
-Longer echo trail
-Fix dont import white track colour from Serato tags
-Fix potential crash when trying to read password-protected zip
-Fix freeze that could happen with some bad ASIO drivers during init
-Fix rare crash favorite folder that no longer exist
-Fix rare crash in tag editor
-Fix rare crash when analyzing file
-Fix Update prompt no longer hidden behind video window on Mac
-Fix audioOnlyVisualisation drop down not enumerating when language was not English
-Fix occasional vob/mpg problems on mac
-Fix secondary skin windows opening on start on mac, even when shown=false
-Fix sampler_group_mute
-Longer echo trail
geposted Sun 11 Oct 15 @ 3:52 pm
Longer echo trail - Getting better but still not getting the same result from 2 clones , abrupt cut off when trailing echo output reaches 2%
geposted Sun 11 Oct 15 @ 4:40 pm
With this build when u play a song and go on to the next its not marking off the last song u played so u no down the line u played that songs already.
thanks
thanks
geposted Sun 11 Oct 15 @ 5:32 pm
Tag editor not coming up......
geposted Sun 11 Oct 15 @ 5:56 pm
Tag editor not coming up...... confirmed for me to!
geposted Sun 11 Oct 15 @ 7:01 pm
2x can't get to the editor.....OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM.png
geposted Sun 11 Oct 15 @ 7:04 pm
Confirmed here too! No Tag editor? Also "effect_show_gui" will not dock for deck 3 it is floating and stuck.
when selected decks 1,2 and 4 are ok.
Jon J.
Jon J.
geposted Sun 11 Oct 15 @ 7:52 pm
Tag Editor not comming also on Win.10
geposted Sun 11 Oct 15 @ 8:28 pm
confirmed (Mac OS 10.11). We need a quick fix for this...
geposted Sun 11 Oct 15 @ 8:34 pm
You can assign file_info to a custom button as a quick solution.
[later] Ah, no you can't. That only works if a track is on a deck.
Unfortunately browsed_file_info doesn't work either.
geposted Sun 11 Oct 15 @ 8:38 pm
Yup... no tag editor for me as well - Windows 10.
geposted Mon 12 Oct 15 @ 1:23 am
Yup were almost there but it should fade out completely........
geposted Mon 12 Oct 15 @ 1:31 am
The Tag Editor unable to open,but...other editor without any problems.
geposted Mon 12 Oct 15 @ 2:17 am
Hello - Tag editor does not open with b 2497 french
geposted Mon 12 Oct 15 @ 7:45 am
