My Poket DJ Duo works in the audio settings area, and I can get the sound part of the controller to work fine, but on the buttons for Deck B work and are available to be mapped. I know the controller is sending out midi data, cause it works fine with Deckadance 2, the software that came with the controller. I also checked the controller on midiox and its working. All deck A controls and all the knobs and slider will not show up in the mappers hwne trying to keylearn. Somebody please help me!
geposted Sun 11 Oct 15 @ 5:50 pm
are you sure vdj supports this unit?
geposted Sun 11 Oct 15 @ 6:05 pm
i dont believe they do, but my soundcard on it works . and right deck controls work. even though it sends midi from all buttons in midi ox. im confused
geposted Sat 17 Oct 15 @ 12:34 am
i mainly need an xml definition file for it
geposted Sat 17 Oct 15 @ 12:35 am
geposted Sat 17 Oct 15 @ 12:44 am
There is a utility program in the download area for making definition files...
It's a bit tedious and time consuming but would probably be faster than writing manually.
https://virtualdj.com/addons/12994/VDJ_MIDI_Controll_Definer.html
geposted Sat 17 Oct 15 @ 9:02 am
