Topic: Slideshow as audioOnly visualisation
I don't know if I did something wrong, but here is what happened.
I'm using slideshow as audioOnly effect with a video loaded.
After opening VDJ the plugin is initializing correct and the video is shown.
But if you disable and enable the video output for some reason, using Ctrl + V, the video of the slideshow will never appear again.
I tried to change the audioOnly plugin and back to slideshow, but it doesn't help.
I had to close and reopen VDJ to get the slideshow video again.
Is this a bug or am I doing something wrong?
geposted Mon 12 Oct 15 @ 9:33 am
hello my something similar happened to me last night
profit not order the video I want to see the public
that's very bad when you put certain material to the public
BUILD 2497 pc
