Topic: Karaoke lyrics on big screen
Ally990Home userMember since 2015
Hi there, I am currently using Virtual DJ 7 for home karaoke. How do I get the lyrics to be displayed on a full screen instead of a small box on the screen.
Thanks
geposted Mon 12 Oct 15 @ 6:30 pm
You will need a Pro License for this feature. You can test this with the Home Free license for 10 minutes
http://www.virtualdj.com/wiki/How%20do%20I%20output%20video%20or%20karaoke%20to%20a%20TV%20or%20projector.html
Alternatively, you may use VirtualDJ 8 which allows full screen video without time limit but with a VirtualDJ logo always displayed.
http://www.virtualdj.com/download/index.html
For version 8, all you need to do is drag the video window to the extended monitor and double-click inside that window, to get the maximized view.
geposted Mon 12 Oct 15 @ 6:39 pm
Thanks DJ Dad..
geposted Mon 12 Oct 15 @ 6:54 pm
Looking for someone to help me I'm new to karaoke an I have vdj 8 an want to start using karaoke what do I need to do to get this to work plz help
geposted Tue 24 Oct 17 @ 9:11 pm
jucenicPRO InfinityMember since 2012
Just get karaoke song and play it. It's very simple, same like play videos.
geposted Wed 25 Oct 17 @ 6:09 am
I have just imported all of my Sunfly in to this and have to say it works a treat.
One thing to be careful of is your using multiple decks (4 or more) then make sure that you select the player button (next to the cross fader) that will be playing the video or you get audio but not video. I made this mistake when trying it for the first time.
geposted Sun 05 Nov 17 @ 2:36 pm
