V DJ guys! please add the tab/slider to change the pitch of the song playing on VDJ 8. it will be very helpful and entertaining too. the pitch can be adjusted for the next song as now the feature is not there is causes a bit inconvenience to mix. it all repies on the KEY(A, a#, b, B#) or else the harmonic factor. it woud be more awesomme if ya'll add that feature too. so please do this feature in the next update.
thank you!
thank you!
geposted Wed 14 Oct 15 @ 7:57 pm
You can already adjust the pitch (speed) of the track in VDJ. That's the purpose of the long fader next to the jog wheel.
The key of the track (if that's what you meant) can also be changed by using the key controls. See page 11 of the VDJ User Guide.
The above refers to the default VDJ 8 skin. Other skins may differ.
geposted Wed 14 Oct 15 @ 8:30 pm
And in the default skin, you could use the custom slider (right-click the knob under the 4 custom buttons) and assign it to 'key' or 'key_smooth' if you prefer to use a slider to alter the key.
geposted Thu 15 Oct 15 @ 4:40 am
