Forum: Old versions
Topic: MIC Mappers
I stumbled across the key mappers in CONFIG, and need some advice. I have VDJ7 Broadcaster
What I'm wanting to accomplish, and having trouble with, is I'd like to have a key stroke combo where I bring the Left gain down "to 9 o clock", so I can talk to listeners on my stream - then have a key stroke to turn it back up with say, a CTRL_SHIFT_S
I tried setting up a CTRL+SHIFT+A, and doing that, but it didnt work when I hit the key combo... Tips/advice?
geposted Mon 19 Oct 15 @ 10:19 pm
Deck 1 gain 25%
And for bringing it up again
Deck 1 gain 50%
You can also mal oz like this
Deck 1 gain 25% while_pressed
But then I'd recommend to use a key like CTRL that doesn't repeatedly trigger the key.
