-Fix regression crash in update popup on Mac
geposted Wed 21 Oct 15 @ 10:31 am
Awsome!!!VirtualDJ 8 is getting better and better.Thanks all Engineer...
geposted Wed 21 Oct 15 @ 11:58 am
crashed again during upgrade 2520 - 2522
geposted Wed 21 Oct 15 @ 12:03 pm
The bug was in 2500 and 2520, so only automatically upgrading from 2483 or earlier would not cause the crash.
geposted Wed 21 Oct 15 @ 12:09 pm
I downloaded 2483 again, and than there was no problem upgrading to 2522.
geposted Wed 21 Oct 15 @ 12:14 pm
这次的更新神速啊 给赞!!!
geposted Wed 21 Oct 15 @ 1:07 pm
after update had to reinstall and played Ok play wilt it all day at work and did a set on VDJ-Radio played ok next day today open and crash after crash open back up and I close it NOW will Not Open get to go back a 2nd time to Open VDj-8....OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM.png
geposted Wed 21 Oct 15 @ 1:43 pm
Load songs over 1hr long now show Streaming Deck....
Sorry the Max Preload length some how got change when I Reinstall VDJ-8
geposted Wed 21 Oct 15 @ 4:10 pm
Am I going bonkers?, where's the track editor gone?, I used to be able to right click on a paused tracks cue point and the editor (or whatever it's called) pops up where I could type in (for example) and tell cue 5 to go to cue 6 or in VDJ8 speak goto_cue 6. what pops up now is the POI editor instead which does not have that function. Have you guys broken this function or have you moved it elsewhere or has my on and off dyslexia re arranged the wording to confuse me? . This might not be a regression btw
geposted Wed 21 Oct 15 @ 8:51 pm
New Crash after startup Virtual DJ
Process: VirtualDJ [2554]
Path: /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Version: 8.0.0 (8.0.2520)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: VirtualDJ [2554]
User ID: 501
Date/Time: 2015-10-22 07:03:32.047 +0200
OS Version: Mac OS X 10.11 (15A284)
Report Version: 11
Anonymous UUID: ECDC6733-BAEB-FAC5-10A0-CC47EB58F6AA
Time Awake Since Boot: 100000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000020
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x20:
__TEXT 0000000109399000-000000010ac91000 [ 25.0M] r-x/rwx SM=COW /Applications/VirtualDJ 8.app/Contents/MacOS/VirtualDJ
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.atomixproductions.virtualdj 0x0000000109463f6b 0x109399000 + 831339
1 com.atomixproductions.virtualdj 0x00000001095171f8 0x109399000 + 1565176
2 com.atomixproductions.virtualdj 0x0000000109499347 0x109399000 + 1049415
3 com.atomixproductions.virtualdj 0x0000000109755cee 0x109399000 + 3919086
4 com.atomixproductions.virtualdj 0x00000001099c77df 0x109399000 + 6481887
5 com.atomixproductions.virtualdj 0x0000000109499244 0x109399000 + 1049156
6 com.atomixproductions.virtualdj 0x000000010939af14 0x109399000 + 7956
User ID: 501
Report Version: 11
geposted Thu 22 Oct 15 @ 5:04 am
Quote :
That's the crash that was fixed in 2522.
You'll have to install it manually if trying to updat from 2520 or 2500.
geposted Thu 22 Oct 15 @ 5:40 am
This was always part of the POI editor. You just have to change the type of the cue point to Action in order to add an action to that cue point.
geposted Thu 22 Oct 15 @ 5:41 am
Yes, i wondering about this. I had make a new download, than an update and think i had the aktually new build.
after this turnaround again, now i check my Version and see the actually Build 2522... I hope there are no more chrashs
geposted Thu 22 Oct 15 @ 6:17 am
My apologies, it was a recent update from Malwarebytes which prevented the drop down arrows from showing on the POI editor which was totally white yesterday, I only found this out as other programs were acting up and looking different as well.
geposted Thu 22 Oct 15 @ 10:23 am
invert_deck does NOT work on deck 4. Works well on deck 1/3 and on deck 2
geposted Sat 24 Oct 15 @ 11:33 pm
what have you got it mapped to and what is the full syntax you're using?
eg. holding 1500ms ? invert_deck & refresh_controller 'CDJ2000' : nothing
geposted Sun 25 Oct 15 @ 9:45 pm
invert_deck 'right'
geposted Sun 25 Oct 15 @ 10:50 pm
Can we get more detailed descriptions on how things work and what they actually do? Its been hell trying to learn this program by googling and coming on these forums. Especially the crossfader curve. There is no visual or description on what full, smooth, cut and scratch actually do
Can we also get more control over the crossfader curve and fader curve? I would love to have a s curve if that's possible. I just want the crossfader to act like a real mixer.
geposted Mon 26 Oct 15 @ 1:31 am
Souf Centrol wrote :
look up Dj V8 but by FRUiT it has info/setting about this this skin you can play & see the full smooth cut scratch and you set the one you like set up it to oninit with Keyboard and when controller hook up
geposted Mon 26 Oct 15 @ 3:44 am
I have that skin. Let me give it a second chance. I don't remember a section to visually see the crossfader curve. Gonna put it on now and check it out
Edit: Thanks, that's atleast 1 more fader curve I can experiment with
geposted Mon 26 Oct 15 @ 4:40 am
