Forum: Old versions
Topic: Numark Mixtrack randomly disconnects
I've been having issues lately with VDJ8. Out of sudden, on random occasions, Numark Mixtrack Pro 1 will automatically turn off, basically like I would disconnect USB cable. The only thing that help is that I unplug & plug USB cable from computer and then it starts to work again perfectly fine. I've already tried with different USB cable and different USB port (I don't use USB hub though) and it's the same. I don't have any problems with other USB devices whatsoever. OS is freshly installed and fully updated Windows 10. Any ideas?
geposted Thu 22 Oct 15 @ 10:45 pm
Have you checked your Device Manager, ensure that the USB ports cannot be turned off by the system to save power.
Yes, I've already unchecked power saving mode for all USB devices.
