With builds changing over time and the end users getting caught up with installs and re-installs.kindly chime in on what system you are using that has worked flawlessly without any issues.i am talking about vdj 7.4 stability type of setup where it was plug and play.currently i have Ns7, Asus g73jh windows 7 pro 64 bit @ 16gb ram,Ati 1gb video card.In my case all updates since 2325 have all had issues here and there.the latest build is actually freezing,i have video lags or static or choppy play,or a sudden crackle that only goes away if you unplug and plug the ns7 usb which is annoying in todays djing age.it could be a numark driver problem (i have the latest driver) or it could be a vdj8 problem even though the initial vdj8 setups were flawless.Thanks
geposted Sat 24 Oct 15 @ 11:04 am
