Forum: Old versions
Topic: Dual Controller Setup?
Hey all! Im running a pair of CDJ 2000 NXS in HID with VDJ8 and was wondering if its possible to also run a controller in order to control 4 decks.
geposted Mon 26 Oct 15 @ 2:57 am
Yes it is. You can connect as many controllers as you wish at the same time.
You will have to do some adjustments on the mappers page on config manually (to tell VirtualDj which controller controls what deck) but other than that everything should be smooth.
