On my Mac, In Virtual 8. I re-arrange the mix into the auto mix in the correct order that I would like it to play, then saved in auto mix . I transfer My order into a Virtual folder
and When I do, it mixes up the order not the way I wanted to auto mix, very frustrating.
Can this be fixed? And how can I do this, so MY AUTOMIX STAYS THE WAY I ARRANGED IT.
geposted Mon 26 Oct 15 @ 4:39 pm
Save as playlist. Right click on column heading. Reset sort order.
Don't know it filter folder will allow that. I use the above method.
geposted Tue 03 Nov 15 @ 1:44 am
Virtual Folders don't have an order, just like regular folders.
What you are looking for is indeed a playlist.
geposted Tue 03 Nov 15 @ 1:59 pm
