Discussion about DDJ SX2
    geposted Mon 26 Oct 15 @ 10:56 pm
          Hi
Do you have a description of the customer mapper and what it does?
Thanks.
Thanks.
geposted Fri 30 Oct 15 @ 6:15 pm
          The mapper doesn't work for me, it has many problems... Is it me or it's a general problem???
    geposted Sat 07 Nov 15 @ 4:31 pm
          the mapper works perfectly in my sx2 , which has reference is the colors of the hot cue , likewise colors roll and loop slicer that are modified to be colorful and natives are not as virtual dj .
Hence the jog that is intermittent as serato when will termirar a track.
geposted Wed 11 Nov 15 @ 1:27 am
          thanks bro work for me
    geposted Sat 09 Jan 16 @ 3:30 am
          This version is included when the function key, some asked how to deploy and works with the key filter to turn the key mode you just have to activate the slip and ready mode , and if not disabled and operates the filter next by default, in a next I will implement a mode pad type , but I am testing to see if it can do other work such software.
En esta version esta includo la funcion de key, que algunos preguntaban como poder implementarla y funciona con la tecla de filtro, para activar el modo key solo hay que activar el modo slip y listo, y si no se desactiva y funciona el filtro que viene por defecto, en una proxima voy a implementar un tipo pad mode pero estoy en pruebas para ver si se logra hacerlo trabajar tipo los otros software.
geposted Mon 28 Mar 16 @ 10:39 pm
          pero no salen los pad de colores diferentes solo sale azul y rojo
    geposted Sat 11 Jun 16 @ 7:12 pm
          si salen estimado, de los colores predefinidos igual si se desea salen los clores que el usuario los ponga al instalar debes escojer este mapper no el default que ese sale los colores que tu dices, me avisas o por interno te ayudo, saludos
    geposted Thu 16 Jun 16 @ 7:25 pm
          Please keep the discussion in English only
    geposted Sat 18 Jun 16 @ 2:12 pm
          ok, thanks
    geposted Sat 18 Jun 16 @ 9:24 pm
          alguien me lo puedes pasar porfavor  :  cue shutter led gog cedj led hot roll led slicer
Moderation : Email has been removed. No license users are not allowed to post contact information
geposted Fri 21 Dec 18 @ 2:10 am
          foupoufé  me méde david guetta  é fun radio si sa fou dé renje pa
    geposted Thu 22 Aug 19 @ 12:14 pm
