If I start to download and then cancel a track the whole program freezes and needs to be re-booted ?.
geposted Tue 27 Oct 15 @ 9:15 am
I tried it a couple of times (make a search, right-click track, download to cache, then right-click again while it is downloading and select cancel) and I didn't get any freeze.
Can you describe more specifically what you did?
geposted Tue 27 Oct 15 @ 9:27 am
Exactly what you did ?, can it be that I'm using Windows 10 ?
geposted Tue 27 Oct 15 @ 11:52 am
I've been using Windows 10 as well since it came out.
Did you load the track to the deck as well before selecting to download it?
geposted Tue 27 Oct 15 @ 11:57 am
Yeah I always play the track before I download it (quality), but it now freezes if I decide to stop the download. ?
geposted Tue 27 Oct 15 @ 2:47 pm
This has been happening to me aswell back when CU first came out.
Sometimes to the point of having to shut down VDJ threw task manager.
geposted Tue 27 Oct 15 @ 3:04 pm
It's definitely reared it's head again, mines was brought on by poor Internet connection, which is hard to replicate.
http://www.virtualdj.com/forums/204833/VirtualDJ_8_bug-report_Forum/Crash_and_problems_with_content_unlimited_.html
geposted Tue 27 Oct 15 @ 10:39 pm
So you select download to cache once the track is fully loaded on the deck, or while it is still downloading?
geposted Wed 28 Oct 15 @ 8:15 am
Sometimes both ways but usually while it is loading
geposted Wed 28 Oct 15 @ 2:48 pm
I have found that this is not a good idea. Let the track load and then download it. I have never had a crash doing this, but it does cause a slow down. I do not have an issue with cancelling a download, but then again I don't use Windows 10.
geposted Thu 29 Oct 15 @ 6:37 pm
