Hello. Does anybody know if ddj-rz or ddj rx can be used in external mixer mode configuration with vdj8 ? Thanks.
geposted Sat 20 Feb 16 @ 4:10 pm
DDJ-RZ can be used in external mixer mode.
DDJ-RX cannot. It can only be used with software mixer
geposted Sat 20 Feb 16 @ 4:14 pm
Only the Z series has the ability to be used in 'external mixer' mode. The X series has to be used in 'master/headphones' mode.
As stated earlier in this thread, the R versions are not currently supported natively in VDJ 8. They are Rekordbox DJ controllers.
If you want a unit to use with VDJ, choose the S versions (SX/SX2/SZ). They are almost identical to the R versions.
geposted Sat 20 Feb 16 @ 4:19 pm
Received a Pioneer DDJ-RZ...happy to assist with developing a MIDI mapper.
@PhantomDeejay...PM sent :-)
Pioneer do say you can 'force' the controller for general MIDI mapping regardless of whether Rekordbox is running or not.
See page 24 of the RZ manual under 'Changing the Settings', 'Utilities Mode' - 'Forcefully using the unit as a general MIDI controller". There are a bunch of other settings that can be configured as well.
Power ON while holding the 'Shift' and 'Play/Pause" button, release the buttons, then press 'Master Tempo' button on left deck (red light need to be on), then switch controller off to save setting.
geposted Thu 17 Mar 16 @ 5:00 am
You don't need to "force" the unit on "General MIDI" mode. If Rekordbox is not running the unit will automatically fall back to "General MIDI"
However "General MIDI" has some limitations that we are trying to resolve.
Thank you!
Thank you!
geposted Thu 17 Mar 16 @ 7:29 am
hi Guys Im Still Waiting For The DDJ-RZ Mapper :) lolol
geposted Tue 22 Mar 16 @ 9:17 am
Hi Guys, no news about this mapper?
Thanks,
Kaléo.
Thanks,
Kaléo.
geposted Mon 02 May 16 @ 2:33 pm
Any mappers?
geposted Mon 29 May 17 @ 3:28 pm
No mapper needed. Support is built in (as can be seen from the Supported Controllers page of the VDJ wiki).
geposted Mon 29 May 17 @ 3:53 pm
