Forum: Old versions
Topic: Loop save
I am hoping someone could help me with loop save. I am new to vdj and am a novice at best. When I first got vdj 8 I was able to make a loop then save it by hitting save in the loop expanded menu. After connecting my hardware everything works as advertised but I've lost the loop save function. I have checked the user Manuel but have not been able find a solution. Thanks in advance
geposted Fri 30 Oct 15 @ 8:37 pm
There is an issue at the moment with the Saved Loop buttons on the skin, which will be fixed in the next update.
For now, you will need to use custom buttons (or modify the actions on your controller) and declare the Slot.
So instead of loop_save (which is the action assigned to the SAVE button on the default skin), you should have .. loop_save 1 (to save the loop to Slot 1) and loop_load 1 (or loop_load_prepare 1) to trigger the Saved Loop.
when can this next update be expected?
