I was told today (by a fellow VDJ user) that there is a feature within VDJ that will automatically collect (via filter settings that I choose) songs that I frequently play, and place them in a "Virtual Folder". For instance, I could choose for VDJ to add any song that I play more than 10 times to this "Virtual Folder", and it will do it automatically. Is this a real feature? If so, how do I set it up?
geposted Tue 03 Nov 15 @ 12:03 am
check out page 53 and 54 of the user manual
your looking for info about " Filter folders"
also check out the "My Library" add-on -> https://virtualdj.com/plugins/?category=other
geposted Tue 03 Nov 15 @ 1:14 am
please also see the according topic:
https://virtualdj.com/forums/205008/PC_Version_Technical_Support/Accessing__played_song__programmatically.html
geposted Tue 03 Nov 15 @ 7:38 am
Install MyLibrary https://virtualdj.com/plugins/?category=other&search=library
I am sure you will find a lot of Filter Folders examples that you can use or modify
geposted Tue 03 Nov 15 @ 1:09 pm
