After hearing from another forum member about I question I have it seems like there may be a small bug in VDJ8. I am using the American Audio VMS4.1 on a windows 10 machine. I have a controller license for the VMS4 and have logged in to ADJ8. ADJ8 recognizes the license and I am able to control all functions with the VMS4.1 as well as play music through it. The bug that I am seeing is yellow triangles showing up in the audio card tab of the settings menu. The American Audio VMS button under the card tab also does not stay highlighted blue when selected. Everything seems to be working correctly but the error triangles are visible. I have attached a screen shot of the issue.
.png)
geposted Thu 05 Nov 15 @ 2:42 am
as stated by our CTO, this is just a "cosmetic" issue (since everything is working fine) and will be fixed in a future update
http://www.virtualdj.com/forums/205049/PC_Version_Technical_Support/Yellow_Triangles_in_audio_settings.html
geposted Thu 05 Nov 15 @ 5:21 am
Thank you.
geposted Thu 05 Nov 15 @ 4:15 pm
