This happened to me again tonight for the second time. I have a playlist which is pretty much a list of songs I have played at a particular venue. Today I had been working on it and saved it several times as the same name it had been before. When I got to my gig and clicked on the playlist it was completely empty.
It was around an hours work down the drain. I have a backup of the playlist but it was the unmodified one.
This is the second time this has happened to me. Anyone else had this issue?
geposted Fri 06 Nov 15 @ 10:43 pm
Here's the playlist that has nothing in it. There is data but it's unreadable in notepad.
Looks like it's been corrupted when being saved within VDJ.
https://www.dropbox.com/s/uk7mapu4c4gd5k5/aaa.m3u?dl=0
geposted Sun 08 Nov 15 @ 7:04 pm
never seen this one ...
maybe a how you made the list procedure would help trouble shoot .. since we all have different work flows.
the way i do and i haven't had this issue is ......
1. i drag the stuff i need to the side list
2. right click playlists and make a new one
3. drag the files to the list from sidelist
also i have auto save for playlists on if that matters
geposted Sun 08 Nov 15 @ 11:10 pm
Did you try a check disk on your hard drive?
It indeed doesn't look like anything virtualdj would write to the file.
geposted Mon 09 Nov 15 @ 9:12 am
Hi Adion,
Just done a check and the drive is fine, the machine it was written on has a 128gb SSD and there are no errors.
This is the second time it has happened, and I'm sure it has something to do with when it is saved.
One thing I noticed is that sometimes when you go to "overwrite" a playlist with the same name, sometimes it asks if you want to replace the file and sometimes it does not.
Keith
Keith
geposted Mon 09 Nov 15 @ 9:49 am
What is the Drive Letter for this SSD ? Keep in mind that VirtualDJ wont be able to write on Drive Letters like A or B (starts from C)
geposted Mon 09 Nov 15 @ 3:57 pm
It's the normal C drive and the playlist is in it's default location.
geposted Mon 09 Nov 15 @ 4:13 pm
