Forum: VirtualDJ Skins
Topic: Original Skins
Hi, hoping somebody can help me. I haven't used VDJ in about 5 years. Just started to use again but can't find the skin that worked best for me. I thinbk it came with version 3 or 4, two turntables with record button on front and loops that you could set within a track then play the track from start and the loop would kick in at the point you marked it. Any help greatly appreciated.
Mikey
geposted Sat 07 Nov 15 @ 4:08 pm
Why not update to the newer version, much better.
Only other option is keep searching the skins section.
Skins that old would most likely not work with VDJ 8. A lot of coding has changed since then.
