Ive made a shortcut to a playlist via the sidelist, i can drag my tracks to this list while its on the right of the screen.
I can drag new tracks to the list and drop them in the order id like but..
Then i click out of this playlist then come back anytime later the list is randomised and i cannot drag and drop to rearrange.
Is this a bug or am i missing some point on this??
geposted Sun 08 Nov 15 @ 2:16 am
Have you click the top of the Files Folder to "Resort" ?
geposted Thu 12 Nov 15 @ 2:57 am
No, I don't want to auto-sort, if for example you have a list of 10 tracks.. you need to put three to the top, its not possible.
geposted Mon 16 Nov 15 @ 4:44 am
I see-
Anytime you make a change to the Playlist in the Automix pane, you have to save the playlist again otherwise as you say, the tracks revert back to random.
So let's say you have a playlist named "Club Bangers"
In order to make changer to this playlist you must:
1. Load Club Bangers playlist into the Automix pane
2. Make your changes to the playlist in THAT pane (Move around tracks, add tracks, delete tracks, etc)
3. Save the Playlist with the same name or create a new playlist
geposted Mon 30 Nov 15 @ 4:41 pm
