When I'm using my controller (Vestax Spin, ik it's pretty bad) mid song my controller stop working and I have to reboot Virtual Pro. IM wondering if it's software and/or software?
Thanks
    Thanks
geposted Tue 10 Nov 15 @ 3:40 am
          Which version/build are you using ?
If you don't have a valid license the controller will stop working after 10 minutes.
geposted Tue 10 Nov 15 @ 10:41 am
          It says that you are a Home User, but you mentioned you are using Pro. Which version are you using?
    geposted Thu 12 Nov 15 @ 7:59 pm
