Hello,
I have a modified question regarding the Reloop NEON from my previous post. How would I get the 4 decks on the NEON to follow the decks on VDJ? Is this something that needs to be done on a programming level, or could I possibly map it?
I'm just looking for the NEON to respond if i press the PFL on my DDJ S1 or in VDJ, instead of working independently of each other. My S1 will follow the decks in VDJ (ie if i press TAB - (deck active select)) it will cycle through the decks on my controller. But the NEON stays put.... Any help would be appreciated!
geposted Sat 14 Nov 15 @ 6:07 pm
The Neon offers 4 hardware deck layers which cant be selected by the software. You will need to manually select the deck by using the deck buttons on the Neon
geposted Sun 15 Nov 15 @ 10:41 am
