Discussion about Mask Transition
geposted Wed 18 Nov 15 @ 11:00 pm
My favourite transition and certainly is what sets me appart from the others..
Brilliant new config interface..
For new users:
Tile: will spread your text across the whole screen as it zooms
Image: will allow you to load a new graphic on the fly
Range: allows you adjust the size of the graphic as it zooms
Brilliant work Scot as always :)
For new users:
geposted Wed 18 Nov 15 @ 11:27 pm
I've been waiting for this for a very long time. Thanks SBDJ
geposted Mon 23 Nov 15 @ 8:45 pm
Hi SBDJ,
because this is not working properly?
geposted Fri 27 Nov 15 @ 4:38 pm
Working fine here:
geposted Fri 27 Nov 15 @ 9:24 pm
Hello Scott, excuse the translation but I do not speak English (use google)
yes, you see the mask,
but I meant to say that the end of the transition does not behave like with your mask,
from video 1 to video 2 transition is smooth and finaly snaps
I hope you understand what I mean
best regards
Erik
best regards
Erik
geposted Sun 29 Nov 15 @ 5:50 pm
It will, that's because of your mask image. As it zooms on the center, there is nothing of the new video in that point on your mask - in the middle of the V. Add a circle there and you'll see what I mean :)
geposted Mon 30 Nov 15 @ 2:39 pm
hola este pluings sirve en virtual 8 pq no me funciona se me pone negro
geposted Thu 03 Dec 15 @ 9:53 pm
Sorry, I only speak English.
geposted Thu 03 Dec 15 @ 10:02 pm
HOW CREATE A MASK IM ON MAC BUT CAN DOIT.
geposted Wed 16 Dec 15 @ 1:32 am
Good morning , I enjoyed this transition, more how do you edit am a formal user, can you explain ? since thanks , Sandro VJ .
geposted Thu 17 Dec 15 @ 10:39 am
as I edit my name ??? you support me with instructions
geposted Sat 25 Jun 16 @ 4:29 pm
how do I download it, Greetings
geposted Sat 25 Jun 16 @ 6:18 pm
Buy a Pro license and then click the link in the first post. It's only available to Pro users.
geposted Sat 25 Jun 16 @ 8:40 pm
Hello guys.
Can someone please tell me hoe to make virtual dj 7 transitions work with virtual dj 8 when installed?
geposted Thu 21 Jun 18 @ 9:52 pm
meddie rustu, make sure you have the same installation folder
geposted Fri 06 Jul 18 @ 5:15 pm
is no longer available for download?
geposted Fri 17 Aug 18 @ 6:07 pm
Scott, will this be ported to 64bit please?
Ive used this at every gig since you first made it and id like to continue using it please??
geposted Mon 14 Oct 19 @ 12:27 pm
Last update It was removed from VDJ, I Loved It, can you make it available again ? PLEASE!!!!
geposted Thu 30 Apr 20 @ 10:27 pm
if already using VDJ 32bit can get it from there (pro only)
https://www.virtualdj.com/addons/14734/mask.html
Was not ported to SDK8, but sdk6 already supported in VDJ2020 32bit
unsupported in 64bit
Would like to see it for both ^^
geposted Fri 01 May 20 @ 12:39 pm
