Forum: Old versions
Topic: Stanton SCS.4DJ light are not working.
Hello,
The light on the buttons don't seem to light up with Virtual DJ 8. Is this an issue or how the controller works? Thank you.
geposted Thu 19 Nov 15 @ 11:09 pm
Power cycle the unit.
SYSTEM->Midi Controller->Midi Channel. Make sure its on Channel 1
Just checked. It's on channel 1, but no lights turning on.
Not sure. I even updated mine to the latest Firmware 5.0 and still all LEDs are working fine.
If none of the LEDs are working for you, can you try with a different USB port, USB cable and maybe a different computer to double-check ?
I have the latest firmware too... Tried all the above besides trying it on another computer. All I have is this Mac to use this on. Are you on a Mac? Thank you for your help.
Didnt try on the Mac. Yes, you are right . LEDs dont work on Mac here either. Will investigate further , email Stanton and will let u know.
Btw, since the unit doesnt work in VDJ7 either, my guess is that there is compatibility issue with the new Mac OS.. I am running 10..11 here btw.
Sure. I hope it gets worked out soon.
Any update on this? I'm on El Capitan too...
