Hi guys - I hope this is a real simple one. I've spent 4 hours trying to solve it, with no joy.
I have a DJ2GO controller which has until recently been by 'just in case' standby unit. I'm trialing VDJ8 at home, and have a REAL niggly issue with the jog wheel. It's scratching in both play & pause mode.
What I need is scratch in pause mode, pitch bend in play mode.
I just can't get it to perform that... it does it fine in VDJ7!! Can anyone please advise how to do it?
The default is audio_scratch = jog wheel.
The mapper seems to be in permanent key learn mode, so trials I do & keystrokes are all being recorded.
Sorry to sound thick, unfortunately I'm just a DJ & not a programmer. A lot of the instructions & notes might as well be written in Japanese.
Build 2522.1079
Rusty 3.1 skin
Win7
Thanks guys
Build 2522.1079
Rusty 3.1 skin
Win7
Thanks guys
geposted Sat 28 Nov 15 @ 6:46 pm
UPDATE : Found it!!!
For anyone else with a similar issue, in options & Tweaks\Audio\vinylMode was set to yes.
I knew thaw minutes after posting the question I'd find the answer myself!
geposted Sat 28 Nov 15 @ 7:03 pm
Sorry - further update: This hasn't worked.
The jog wheel doesn't pitch bend now.
Also - is there a setting for increasing the speed (sensitivity??) of the scratch in pause mode?
cheers
geposted Sat 28 Nov 15 @ 7:10 pm
try to map the JOG as .. touchwheel
geposted Sun 29 Nov 15 @ 3:12 am
Thank you - it seems to be working ok now after a restart :) I have another query too which I'll post as another thread to save confusion.
Neil
geposted Tue 01 Dec 15 @ 12:18 am
