Forum: VirtualDJ 8.1 Technical Support
Topic: Microphone dosn´t work
Hello i need help i have an auna mic 900b and vdj dosnt work with it can anyone help?
geposted Sat 05 Dec 15 @ 6:57 pm
this is a USB mic correct?
there is a on off switch for the MIC on the master panel.
did you add the mic as an input in your sound config?
more info about your setup and equipment would be helpful also a screen shot of the sound config.
geposted Sat 05 Dec 15 @ 7:10 pm
Fail
geposted Sat 05 Dec 15 @ 7:46 pm
the button in this image to the right side that says ON turns the mic on/off
click the master tab below sandbox to see these buttons
your audio config looks correct
geposted Sat 05 Dec 15 @ 8:49 pm
yeah when i turn them on and talk they dont react ^^
geposted Sat 05 Dec 15 @ 8:50 pm
open the windows control panel then
open sound
click the recording tab at the top
select your mic in the list
click properties
a new window opens
goto levels tab
turn up the slider 90% or so and try again.
geposted Sat 05 Dec 15 @ 8:54 pm
not working he dont react i dont know why he dont will talk
geposted Sat 05 Dec 15 @ 9:04 pm
can anyone help?
geposted Sun 06 Dec 15 @ 11:54 am
Did you check that the mic works with your operating system?
geposted Sun 06 Dec 15 @ 1:22 pm
yes i can talk with it in teamspeak or other think but VDJ dosn accept
geposted Sun 06 Dec 15 @ 2:01 pm
I´ve got the same Problem! You have to set your VDJ Settings like the following Strucutre:
Source: mix
SoundCard: Auna mic...
Channel: Chan1(mono)
then it works. I hope i coud help.
geposted Sun 15 Jan 17 @ 6:33 pm
