Hey all, I'm not entirely sure the syntax used if I'm trying to map key changes to an endless knob. I would like to be able to cycle up and down through individual Key changes, but thus far I've only been able to achieve this in one direction, or more as an on/off style switch. I feel like a Param command isn't correct for changing the keys, but at this point I'm stumped. Any suggestions? Thanks in advance.
geposted Tue 08 Dec 15 @ 4:56 am
Try param_smaller 0 ? Key -1 : key +1
However just typing "key" should also work since the value of the encoder is passed as an implicit parameter
geposted Tue 08 Dec 15 @ 8:12 pm
Updated: Okay, stumbled around and figured out this script:
param_greater 0 ? key_move +0.5 : key_move -0.5
now I'm stuck trying to add shift modifiers to allow control of the effects with more complex instructions, and I'm a bit stuck with order of operations I think.
I tried,
var "shift" ? effect 2 select : param_greater 0 ? key_move +0.5 : key_move -0.5
It didn't work for the key_move at this point.
geposted Tue 08 Dec 15 @ 8:16 pm
Tell us what you want to do. Then we can answer and analyse the script so that you start learning.
geposted Tue 08 Dec 15 @ 8:18 pm
Post updated.
geposted Tue 08 Dec 15 @ 8:22 pm
Hey, OP here. Lvx is just my buddy who was posting our problem from his setup.
geposted Tue 08 Dec 15 @ 10:19 pm
