Someone posted a nifty utility for finding all the midi code sent from a midi hardware controller. Can someone point me to that link. Or is this file available to download from VDJ? Can't seem find in search.
geposted Tue 08 Dec 15 @ 8:05 pm
You can find it on this page https://virtualdj.com/wiki/ControllerDefinitionMIDIv8.html
It's called MIDI Trace
geposted Tue 08 Dec 15 @ 8:10 pm
Thanks phantom... but there was a different one I had in mind. Ive used it before, but forgot the name. The interface for the tracing midi gave every single piece of information that was happening as you hit a button.
geposted Tue 08 Dec 15 @ 10:03 pm
Found it... thanks for helping me look
https://virtualdj.com/forums/146089/VirtualDJ_Plugins/VDJ_MIDI_Controll_Definer.html
geposted Wed 09 Dec 15 @ 12:15 am
MIDI Trace does the same as well. You just need to select the correct ports.
Then if you press a button, move a slider, e.t.c. the MIDI message will appear on screen.
geposted Wed 09 Dec 15 @ 11:19 am
