Forum: VirtualDJ 8.1 Technical Support
Topic: Craig Royale
Hi l have a licence for a mac version of Virtual Dj pro and want to and and use it as a back up on a pc but i can't use it with controller can you help
geposted Thu 10 Dec 15 @ 6:54 am
Since you are posting in the 8.1 Forum, i will assume that you are using VirtualDJ 8/8.1
If that is the case, you will need to install VirtualDJ 8 to your backup computer from http://www.virtualdj.com/download/index.html
Once VirtualDJ 8 is launched to that computer for the first time, you will need to Login with your virtualdj.com account credentials.
In Settings->LICENSEs tab you will then be able to see Pro Infinity under the "current licenses" tab
Your computer needs to be connected to the Internet at least for the first launch.
If for any reason, you are logged in, but dont see the Pro Infinity License, something may be blocking the connection between your computer and our server, so please try to disable any Antivirus and fix your Host files.. http://www.virtualdj.com/plugins/index.html?category=other&search=host
geposted Thu 10 Dec 15 @ 7:59 am
