Forum: Addons
Addons comments
Topic: Hercules Jogvision Optimized Mapper
ciocePRO InfinityMember since 2004
geposted Wed 16 Dec 15 @ 8:06 am
As follow the modification list respect the original mapper:
----- v1.0 (16 Dec 2015) -----
SHIFT -> Added Jog wheel_mode "search" while_pressed
LOAD -> Added prelisten off action
SHIFT LOAD -> Now unload
LOAD PREPARE -> Now prelisten the browser tracks
SHIFT VIEW -> show_splitpanel 'sideview' on & sideview +1
SHIFT LOAD PREPARE -> sideview 'sidelist' ? sidelist_add : sideview 'automix' ? playlist_add
LED SHIFT HOTCUE -> Now PAD Blink in hotCue mode with Shift pressed
geposted Wed 16 Dec 15 @ 8:25 am
----- v1.1 (3 Feb 2016) -----
Controller mappings updated for colored cue points, it require at least VirtualDJ 8.1 b2382
geposted Wed 03 Feb 16 @ 7:47 am
AdvokutPRO InfinityMember since 2010
please update this mapper to support the padmodes function introduced in 8.2
geposted Tue 09 Aug 16 @ 3:29 am
Definition must be updated by team only, then mapper could be updated, we need to wait.
@ Team
Please check pitch slides definition, when are at center I see pitch 0.1% and not at 0.0%
geposted Thu 11 Aug 16 @ 10:26 am
i cant seem to be able to install this modified mapper anymore, it used too.
also i have the issue of two entries for hercules jogvision @ device select options menu, how come?
geposted Thu 20 Oct 16 @ 10:25 pm
The unit offers both MIDI and HID protocols, but unfortunately some Keys (LEDs, faders, buttons etc) are offered on one protocol while others are offered on the other. So we had to map the unit in both protocols, thats why you see 2 Devices in the Controllers List.
Mapper installed fine here (didnt connect the unit though to test), but you probably have to select the "correct" device in order to get the mapping available in the Mappings List.
geposted Mon 24 Oct 16 @ 5:06 pm
prejudice have the mapping can send hercules dj control jogvision me pls link
geposted Fri 06 Jan 17 @ 7:22 pm
hola..! quiero saber como trabaja la suscripción anual?
geposted Sun 19 Feb 17 @ 6:31 pm
necesito un mapper de hercules jogvision alguien me ayuda?
geposted Sun 14 Jan 18 @ 9:26 am
The mapper is already built in to VDJ 8 (the controller is natively supported) so just plug the controller in and it will work.
geposted Sun 14 Jan 18 @ 10:06 am
Buenos dias, alguien ha creado el skin de éste controlador para usar con Virtual DJ 8? gracias
geposted Thu 29 Nov 18 @ 5:14 pm
when will the skin come out for it
geposted Tue 25 Dec 18 @ 5:08 pm
Any VDJ skin is "for it". There's absolutely no need whatsoever to have a skin that replicates the appearance of the controller.
geposted Tue 25 Dec 18 @ 5:49 pm
Hola colegas! alguien sabe o ha creado algun skin para el controlador Hercules Jogvision? agradezco alguna onformación, saludos
geposted Mon 15 Jul 19 @ 11:56 pm
MEU JOG NAO RESPONDE CORRETAMENTE, QUANDO PRECISO ADIANTAR UMA MUSICA ELE FALHA, ALGUEM TEM A SOLUÇÃO?
geposted Mon 04 May 20 @ 12:35 pm
