Is there a way to route the audio from the microphone input on the controller of the reloop terminal mix 2 into the VDJ software application and not through the master output? I have tried flipping the switch on the front of the device but the does not seem to be working...
geposted Mon 21 Dec 15 @ 1:57 pm
Probably the Mic Input is on Chans 3,4 (you need to add a Mic Input to the Audio configuration)
Check the Terminal Mix 4 Manual (Recording & Broadcasting section).. https://virtualdj.com/documents/Reloop%20Terminal%20Mix%204%20-%20VirtualDJ%208%20Operation%20Guide.pdf
should be similar to TM2
geposted Mon 21 Dec 15 @ 4:15 pm
