hello,
is it possible to use 2 different samples on 2 different outputs at the same time?
geposted Tue 22 Dec 15 @ 11:35 am
No, All Samples will play at the same Sampler Output (master by default or the Chans defined in the Audio configuration)
You can still load a sample to a deck of course and have some specific Chans in the Audio configuration for this deck.
geposted Tue 22 Dec 15 @ 11:59 pm
@user12065206
it is possible.........
If you really must, then use 2 laptops :)
geposted Wed 23 Dec 15 @ 2:32 pm
