Forum: Old versions
Topic: VDJ7 Deleted music after Fix
Hello all. I'm going to try and remain calm as I am freaking out. I opened VDJ7 to a corrupted database error. Because I use a couple different pc's at my gigs, this sometimes happens. It's happened before and Fix worked before. This time I fixed it and it deleted music from months of work. Is there a way to recover these files? I'd really appreciate any help. Thanks.
geposted Sat 26 Dec 15 @ 12:42 pm
It is not possible for VirtualDJ to delete your music under any circumstances. They will still be on your hard drive and the database will need to be rebuilt.
Hello: I've backed up all my files from VDJ from my old PC. when I load them on the new PC, The Cache Files play fine, The History & Playlist Files do not play. Although the files are present in VDJ (playlist and history} I still can't play them or refresh them to play. are there any addons that can reload these files? or does anybody know of a trick I'm missing? Thanks! Damon.
Check the file path for the tracks is exactly the same on both machines.
