Forum: VirtualDJ Skins
Topic: CUE RMX Skin by Cioce for VDJ8
mysticaPRO InfinityMember since 2008
geposted Sat 02 Jan 16 @ 2:45 pm
I'm just looking at the skin XML code now, and I see that the logo width is set at 0.
As the height is 17, try a width of 100.
[update] a width of 100 works OK here on PC at 1920x1080.
geposted Sat 02 Jan 16 @ 3:04 pm
How do i do that pls ?
geposted Sat 02 Jan 16 @ 3:08 pm
The skin will be in the VDJ skins folder as a zip file.
Open the zip file and the two parts of the skin are the image (BMP) and the code (XML).
Open the xml file with a text editor and find the part that says:
<logo os="pc">
<size width="0" height="17"/>
<pos x="9" y="1"/>
</logo>
Change the width from 0 to 100 and save the XML back to the zip file.
geposted Sat 02 Jan 16 @ 3:14 pm
I have changed it, zipped it and drag the new skin to vdj skin folder but I can't find there :(
geposted Sat 02 Jan 16 @ 3:51 pm
Found it, thanks for your help! :-)
geposted Sat 02 Jan 16 @ 3:54 pm
No problem!
geposted Sat 02 Jan 16 @ 3:57 pm
fede74PRO InfinityMember since 2006
the skin more 'practice to use ... sin is life with virtual dj 7 .... we would like an upgrade to virtual dj 8 ..... who knows' if cioce the updates !!!
geposted Sun 03 Jan 16 @ 3:18 am
I'd like to increase the music browser height up a bit, so i can be able to see more of my music files, can you pls tell me what's the xml code pls ? thanks
geposted Sun 03 Jan 16 @ 3:32 pm
Probably the easiest thing to do is assign some code to the 'browser' tab (which was made for VDJ 7 but is redundant now) to give you a pop-up floating browser window which you can move around and resize.
geposted Sun 03 Jan 16 @ 3:35 pm
ciocePRO InfinityMember since 2004
geposted Tue 05 Jan 16 @ 1:49 pm
Too bad! cioce that you won't be making a CUE RMX Skin for VDJ8, Im so not impressed! :-(
geposted Wed 06 Jan 16 @ 8:48 pm
The first love you never forget ..... I remain in virtual dj 7 and with the skins of cioce :-)
geposted Thu 07 Jan 16 @ 9:21 am
The skin still works okay with vdj8 so I can't complain much lol!
What I would love is if an update can be made so that the browser option height can be higher up a bit just like Controller by DennYo skin so I can see more of my music and samples.
geposted Thu 07 Jan 16 @ 9:38 am
See my earlier post...
If you can't manage the changes yourself, send me a mail and I'll guide you through.
geposted Thu 07 Jan 16 @ 5:36 pm
In fact the "old" but still my favorite skins cioce, also works in virtual dj 8 .... I placed the logo of the virtual and the blue bar in the mixer ..... but how come I can not change the color bottom of the browser? .... how do I do?
geposted Wed 13 Jan 16 @ 12:08 pm
geposted Wed 13 Jan 16 @ 6:54 pm
