Denon MC6000 and VDJ 8 on mac
I cannot get any of the controls on the mixer to respond in VDJ 8?!
I had VDJ 7 before and everything worked like a charm! Tried different mapping files from this site...yet no luck :(
geposted Mon 04 Jan 16 @ 10:10 pm
Is your MC6000 on PCMIX or INTMIX (rear side) ? By default VirtualDJ 8 pre-defined audio setup is Master & Headphones (for PCMIX). In case you need to use the other mode, you ll need to manually create an External mixer setup (with deck 1, deck 2.. etc) in AUDIO tab of Settings.
Also make sure you test with the default mapping files first.
geposted Tue 05 Jan 16 @ 8:04 pm
