Forum: Old versions
Topic: Database sync between VDJ 7.4 & 8.1
Hi guys, is there a way I can sync the databases between the versions?
I want the files i'm adding to the database to be added at once to both 8.1 & 7.4 versions, installed on my pc.
If it's not possible to do so automaticly, is there a way I can add files to the 8.1 and do something to the 7.4 database file to match the 8.1 file?
geposted Tue 12 Jan 16 @ 10:32 pm
theres a db converter app in tools section have a look
If you're going to contine using both VDJ 7 and 8, consider doing your database work in 7 and then simply start up VDJ 8 without its database (delete or rename it), whereupon it will import the version 7 database again, complete with changes.
