Folder??
How do I set this up with 8?? It keeing grabbing the ones I don't wanna use.
geposted Mon 18 Jan 16 @ 12:59 am
Pin open the transitions selection window and create a folder called Ignore. Drag and drop the transitions you don't want used into there :)
geposted Mon 18 Jan 16 @ 2:09 am
Awesome, that was easy, Thanks.
1 more thing, can you help with a script that unlinks the video crossfader from the crossfader and turns on your auto transition plugin and vice versa??
geposted Mon 18 Jan 16 @ 2:15 am
video_crossfader_link ? video_crossfader_link off & deck master effect_button 'AutoVideoTransition' 1 on : video_crossfader_link on & deck master effect_button 'AutoVideoTransition' 1 off
geposted Mon 18 Jan 16 @ 1:11 pm
Ok I see, I forgot about the "deck master".
Awesome and Thanks!!
geposted Mon 18 Jan 16 @ 1:54 pm
Perfect!! This is exactly what I wanted!!
Thanks for the time and info!!
geposted Mon 18 Jan 16 @ 11:38 pm
No problem. I completely forgot btw, you can just right click > ignore for your original question!
geposted Tue 19 Jan 16 @ 9:21 am
Haha yeah I got the transition part figured out.
And I just love the fact I can shut the auto trans off when I scratch and turn it back on when I need it smooth!! So badass!!
Most appreciated (:thumbs up)
geposted Tue 19 Jan 16 @ 12:48 pm
Can I get the "Random Transitions" turned off as well?? So when AutoVideo Transition is enabled Id like the Random Transitions to active aswell.
geposted Sat 23 Jan 16 @ 7:44 pm
Can I please get the script to turn off/on random transitions??
I tries a few different things but nothing worked.
geposted Mon 25 Jan 16 @ 9:23 pm
video_crossfader_link ? video_crossfader_link off & deck master effect_button 'AutoVideoTransition' 1 on & setting 'videoRandomTransition' on : video_crossfader_link on & deck master effect_button 'AutoVideoTransition' 1 off & setting 'videoRandomTransition' off
geposted Mon 25 Jan 16 @ 11:40 pm
PERFECT!!
Thank you!!
Thank you!!
geposted Tue 26 Jan 16 @ 12:30 am
Can you tell me how I could make this blink when used on a custom button please?
EDIT, I figured it out.
geposted Fri 08 Apr 16 @ 3:57 pm
